Board index : Winstep Forums : General Discussion  [ 45 posts ] Go to page Previous  1, 2, 3  Next
 Post subject: Re: Link doesnt work
PostPosted: Mon Jan 23, 2012 4:20 pm
A better solution would perhaps be to make the dialog appear 'always on top' too.
Ok, but where is this setting? :)
For the screenshot to other problem it's impossible because the opened list menu on the dock, disappear suddenly
Another problem; how I have to set email monitor module for Outlook 2007, I set all parameters in the form of the dock, but it doesnt work
Waterworld
PostPosted: Mon Jan 23, 2012 5:25 pm
I said *would be*. Future tense. There is no setting now (and, in fact, even if/when this is implemented, no setting will be needed).
Press the PRTSCN key, open MS Paint, paste, save as JPG, post screenshot. :D
This tells me nothing, I have no idea how your email accounts are configured in Outlook 2007. If you are trying to get the Email module to check on a Gmail, Hotmail or Yahoo account, you can't because those POP3 connections require SSL v3 and the Winstep Email Checker does not currently support that.
PostPosted: Mon Jan 23, 2012 6:26 pm
Ok
If I click on the window in the center for move or copy file/folder, all opened menu/windows are closed
Ok, i have Gmail
Waterworld
PostPosted: Mon Jan 23, 2012 9:09 pm
Ah, gotcha now, thanks for the screenshot.
That group of options in the file's right click menu are provided by Windows Explorer and any right-click shell extensions you have installed on your system. The copy option you are trying to use will copy the file to the Windows *clipboard*, not to the dock.
What you should do instead is *drag and drop* the file *from the menu that displays it* into the dock.
PostPosted: Mon Jan 23, 2012 9:15 pm
1Al wrote:
Ok, i have Gmail
Just for your information, I'm currently looking into a 3rd party tool that might bring SSL/Gmail support back into the Email Checker (the Winstep Email Checker was one of the very few Email Checkers that *did* support SSL v2 and Gmail accounts, but then a security flaw was discovered with the SSL v2 protocol and Google and the others switched to TLS/SSL v3, which is really difficult to implement).
PostPosted: Tue Jan 24, 2012 11:19 am
Ok all clear now :)
We wait for further implementations of the dock
Waterworld
PostPosted: Wed Jan 25, 2012 4:37 am
the last two day awakening PC from hibernation, always I find this surprise, before ever done in this way
as long as I hover the mouse on the dock everything back in place
could it depend on what?
Waterworld
PostPosted: Wed Jan 25, 2012 7:36 pm
I closed and restarted the bar, for now it seems that the problem has ceased
Waterworld
PostPosted: Wed Jan 25, 2012 7:47 pm
Hard to understand what was happening just by looking at that screenshot. The dock was leaving 'leftovers' as you moused over it, is that it? Could be a graphic's glitch caused by having just returned from hibernation.
Please let me know if it happens again - also, if it does, instead of restarting Nexus try opening Nexus Preferences and clicking OK.
PostPosted: Thu Jan 26, 2012 8:17 pm
Ok, however after that restart the Dock, no longer does that.
Rather than a question; in original Mac dock the trash bin stay on the right of the separator, but why did you put it together with other left-side links ?
Waterworld
PostPosted: Fri Jan 27, 2012 12:22 am
Because Nexus is not the Mac dock. :wink:
PostPosted: Fri Jan 27, 2012 6:45 am
Ok, so a distinctive sign ; )
Rather that problem happens again this morning, but this time there was only one small corner of the dock without items. First I tried the dock settings, but it did the same problem. Instead if I close and restart the dock is no longer the problem for some time. But even in this way, isnt conclusive solution.
Waterworld
PostPosted: Fri Jan 27, 2012 6:50 am
Did you try already opening Nexus Preferences and clicking OK instead of restarting Nexus?
PostPosted: Fri Jan 27, 2012 11:46 am
When the problem occurs still not
Waterworld
PostPosted: Sat Jan 28, 2012 8:45 pm
the problem has come back then I did as you said but nothing has changed. I noticed that the problem occur, only over a long period of hibernation, if I leave pc hibernate a few minutes and wake up the computer, it does not happen
Waterworld
Post new topic Reply to topic Board index : Winstep Forums : General Discussion  [ 45 posts ] Go to page Previous  1, 2, 3  Next
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 96 guests
