 Post subject: Combine Taskbar icons?
PostPosted: Fri Apr 06, 2012 7:25 pm
Is it possible to combine taskbar icons so they are sort of "nested" on the dock icon? Windows 7 provides the option to "Always combine, hide labels" for open programs. Then, hovering over the dock icon would show thumbnails of the instances of open windows for that icon, rather than opening separate icons on the dock showing the open instances.
Anybody know if this is possible with either the free or paid versions of Nexus dock :?:
 Post subject: Re: Combine Taskbar icons?
PostPosted: Fri Apr 06, 2012 7:35 pm
You mean like this? :wink:
Yes, it is possible.
PostPosted: Fri Apr 06, 2012 8:33 pm
Thanks for responding. Actually, it does open as you show. What I'm wondering is if the nesting can take place on the dock icon (shortcut), like it does in Windows 7. Here's a screen print.
PostPosted: Fri Apr 06, 2012 9:12 pm
Ah, no, not currently - that's on the to-do list though.
PostPosted: Fri Apr 06, 2012 11:34 pm
Thanks for the speedy reply. Any ETA on the enhancement? It will really add to the aesthetics of the dock as well as improving navigation. It's a lot nicer just hovering over the icon you know will always be there than looking for the "open" icon on the right side of the dock.
We appreciate your work! Thanks for a great product!
PostPosted: Sat Apr 07, 2012 12:22 am
No ETA, sorry. v12.2 was just released, so the next official update is likely 3-4 months away (with, perhaps, a maintenance release in-between).
There's ample space for improvement in Winstep applications, so there is currently a lot of stuff in the to-do list - but still only a pair of arms. :D
PostPosted: Sat Apr 07, 2012 2:08 pm
Thanks for the quick replies. Great product!
Users browsing this forum: Amazon [Bot] and 267 guests
