 Post subject: Nexus.wsxkey problem
PostPosted: Wed Jun 13, 2012 12:38 pm
Hi,
I have already sent a mail to the support but no response, so maybe someone here could help me.
I bought Nexus Ultimate a few month ago I uninstalled it from the old computer and try now to reinstall it but no way to register it.
I have a Nexus.wsxkey but not associated with a program and when i try to reset this association nothing is working...
Any idea?
Olivier
 Post subject: Re: Nexus.wsxkey problem
PostPosted: Fri Jun 15, 2012 1:19 pm
Hello
Excuse me but is the good mail for support : support@winstep.net ?
PostPosted: Fri Jun 15, 2012 4:08 pm
Winstep support seems to be having some problems with emails lately, sorry... :cry: I'll see if I can find your message and let you know ASAP.
In the mean time, can you please post a screenshot of your Desktop showing Nexus Ultimate open in the About tab *and* also the contents of the Winstep Licenses folder (open Nexus Preferences, go to the Registrations tab, click the Open Folder button).
Thanks,
PostPosted: Tue Jun 26, 2012 7:26 am
Hi,
Thanks for your answer.
Here is the first screenshot, for the second I haven't a registration tab...
How is it possible?
Thanks for your help,
Olivier
PostPosted: Tue Jun 26, 2012 11:37 am
osauneir, you're right there is no registration tab. i got curious after rechecking my preferences, so i found the image below for nexus preferences. you can navagate to c:\users\public\public documents\winstep\license and take and post a screenshot of the contents of that folder.
PostPosted: Tue Jun 26, 2012 12:16 pm
OK thank you that's the result : nothing :)
Thanks for helping :)
PostPosted: Tue Jun 26, 2012 12:33 pm
How is it possible?
It's possible because you are using the *free* version of Nexus. Nexus Ultimate shows the Nexus Ultimate logo in the About tab.
You need to download and install Nexus Ultimate. Do you still have access to the email message with your license key? The link to download Nexus Ultimate is in that message.
PostPosted: Tue Jun 26, 2012 12:51 pm
Ho!!! You mean that registering Nexus Ultimate isn't just a key in the free version, it's a special release?
Please can you send me the link back I haven't in my mail or maybe in Outlook at home :)
Thanks for your help and sorry for my understanding.
Olivier
PostPosted: Tue Jun 26, 2012 1:01 pm
Eheh. Sent you a PM. :D
 Post subject: [Solved] Nexus.wsxkey problem
PostPosted: Tue Jun 26, 2012 1:05 pm
thank you :)
PostPosted: Tue Jun 26, 2012 1:32 pm
But... when i double click on the key nothing happens :( nothing in the folder nothing in the register tab that i see now.
I tried to restore association but not work too.
Sorry :)
PostPosted: Tue Jun 26, 2012 1:50 pm
Sorry :)
close winstep out completely, navigate to c:\users\public\public documents\winstep\license and copy your key to the license folder. now run winstep, open preferences and on the main screen at the bottom see if it says you are finally registered.
PostPosted: Tue Jun 26, 2012 3:44 pm
Bon nickel en fait j'ai ré-associé à la main le wsxkey avec le bon prg et cela a fonctionné. Donc c résolu pour moi merci pour votre aide à tous.
PostPosted: Tue Jun 26, 2012 3:56 pm
translated with google translate:
"Good nickel in fact I re-associate the hand with the right wsxkey prg and it worked. So c solved for me thank you all for your help."
glad you got it resolved.
PostPosted: Tue Jul 03, 2012 12:57 am
Hi support,
I too have the same problem.
Had to rebuild my laptop and do not have the wskey file or the link to download Extreme.
Please advise...
Thanks.
Dennett
Users browsing this forum: Majestic-12 [Bot] and 196 guests
