 Post subject: Winstep Extreme & Windows 8 Pro 64 bit
PostPosted: Fri Nov 30, 2012 6:08 pm
Jorge,
Is the lastest version of Winstep completely compatible with Win 8 Pro 64 bit?
P.S. I have e-mailed you this question, but not sure if you have recieved it.
Regards
 Post subject: Re: Winstep Extreme & Windows 8 Pro 64 bit
PostPosted: Sat Dec 01, 2012 4:54 am
Yes it is. There are two things that don't work: Aero Glass blur (background blur of semi-transparent backgrounds) and the 'Show Start Menu' internal command. Both because Microsoft decided to remove the associated code.
Since Aero Blur is now rendered as solid white under Windows 8, until the next release you should disable the Blur feature (which is enabled by default) in the Themes tab of Preferences.
PostPosted: Sat Dec 01, 2012 3:24 pm
Where is the Show Start Menu that you mention. I have turned off the Blur. Looking forward to update to me Extreme completely 8 compliant. Glad you app works too, didn't want to have to buy someone elses.
Regards.
PostPosted: Sat Dec 01, 2012 3:32 pm
Actually the Internal Command is simply called 'Start Menu'.
You are aware about the availability of Internal Commands in Winstep applications, right? Those are special commands available in Winstep applications to do special stuff, such as Power Off the monitors, etc...
To add an Internal Command to a dock, for instance, just right click the dock -> Insert New Dock Item -> Internal Command -> (Choose the IC category and the one you want)
PostPosted: Sun Dec 02, 2012 8:16 pm
Had no idea about Internal Commands. So is what you mentioned something that is ON by default?
Thank you for getting back to so quickly.
Regards.
PostPosted: Tue Dec 04, 2012 9:09 am
Sorry, what are you referring to? The Internal Commands?
PostPosted: Tue Dec 04, 2012 6:42 pm
Yes, Internal Commands. This is an aspect of Winstep I had no idea about. First I have heard of it.
PostPosted: Tue Dec 04, 2012 10:04 pm
Well, you need to explore some more then! :)
As I said you can add those internal commands to a dock, a 'Regular' tab on the Shelf, or a NextSTART menu by right clicking -> add new item -> 'Internal Command' -> select category and command you want. This will create an entry on the dock/Shelf/menu that, when clicked on, will perform that special action.
Here is a (incomplete) list of Nexus Internal Commands (replace the word 'Nexus' below with 'WorkShelf' for WorkShelf's Internal Commands). Note that some of these commands are dependent on Windows version (i.e.; might not be available on your system).
Nexus Help
Nexus Preferences
Exit Nexus
Quick Exit Nexus
Version Info
Backup Nexus Settings
Restore Nexus Settings
Check for Updates
Show Tip of the Day
More Themes
Capture Desktop
Show Start Menu
Show Volume Control
Run
Search
Find Computer
Windows Help
Control Panel
My Computer
Network Neighborhood
Printers
Start Flip 3D
Start Screen-Saver
Power Off Monitor
Sleep
Hibernate
Log Off
Quick Log Off
Restart Windows
Quick Restart Windows
Shutdown Windows
Quick Shutdown Windows
Fast User Switching
Show Recycle Bin
Empty Recycle Bin
Clear Recent Documents
Show Desktop
Minimize All Windows
Restore All Windows
Show Desktop Icons
Hide Desktop Icons
Hide/Show Desktop Icons
Show Desktop Folder
Rebuild Icon Cache
Show Taskbar
Hide Taskbar
Hide/Show Taskbar
Task Manager
Copy Disk
Format Floppy Disk
Eject CD-ROM
Close CD-ROM Door
Eject Drive x:
Close CDROM x: Door
Safely Remove Hardware
Connect to the Internet
Disconnect Modem
Accessibility Properties
Add New Hardware
Add New Printer
Add-Remove Programs
Date & Time Properties
Desktop Themes
Display Properties
Fax Properties
Game Controllers
Internet Options
Keyboard
Mouse Properties
Multimedia Properties
Network Properties
ODBC32 Data Admin.
Power Management
Regional Settings
Scanners and Cameras
Show Fonts
Sounds
Speech Properties
System Properties
Telephony Properties
Media Previous
Media Play
Media Pause
Media Stop
Media Next
Media Volume Up
Media Volume Down
WinAmp 2.x Preferences
WinAmp 2.x Equalizer
WinAmp 2.x Playlist
Users browsing this forum: No registered users and 121 guests
