Would you like to have more mouseover/launch/attention effects?
Yes, please, please I love those!
36%
[ 4 ]
Meh. I don't care one way or the other.
45%
[ 5 ]
Nah. The ones already there are more than enough.
18%
[ 2 ]
Total votes : 11
 Post subject: Dock mouseover effects
PostPosted: Tue Dec 29, 2015 6:35 pm
So, I've come across some more animation sheets which can be used to add a few more dock mouseover effects, etc...
On the other hand, no other dock anywhere has as many effects as Nexus already has... so...
And while you are at it... please post below what your favorite mouseover effect is. And you know you can combine the dock magnification effect with other effects, right?
 Post subject: Re: Dock mouseover effects
PostPosted: Tue Dec 29, 2015 11:44 pm
My favorite and currently using: Mouseover Effect: Water, Magnified.
Always loved water themes. And yes, more themes would be absolutely wonderful.
Would love more "water" themes including splash hitting the top of icons, with droplets splashing everywhere combined this with water running down the sides of icons slowly as another option. How about lighting strikes. Something to do with the rain or a water stream that flows pass the icons with mouseover. Would like to see the water stream be an entire sheet that spans the entire dock, and only will it rise when mousing over the icons. Just a thought. Appreciate all the added flare to Winstep/Nexus.
PostPosted: Wed Dec 30, 2015 9:17 am
While the eye candy is nice, it eventually wears thin. I'm far more interested in functionality... THAT endures.
Cheers!
Chuck
PostPosted: Wed Dec 30, 2015 6:42 pm
I don't think anyone can say Winstep apps lack functionality. At least not with a straight face. :wink:
Anyway, as you answer the poll, please post your favorite effect too. I'm really curious about this.
PostPosted: Thu Dec 31, 2015 2:20 am
And that functionality is why I still use it and support its development.
Favorite Effect: Squish
Cheers!
Chuck
PostPosted: Fri Jan 22, 2016 10:41 pm
I have some good news for all those who voted yes: some more cool effects coming your way (but will only be available in the paid versions of the software).
PostPosted: Sat Feb 13, 2016 3:37 am
I've only used the "free" version of Nexus; however, one that that always bothered me about your AMAZING dock is that i wish there was a simple hover over effect that could draw like a box or rectangle around the icon like a normal taskbar would. I'd actually like to use Nexus as a taskbar and hence would love to blend it into the screen better by having a bar behind it with normal hover over and select effects. What do you think?
PostPosted: Sat Feb 13, 2016 3:47 am
Hmmm... that would probably look ugly as hell when the dock is magnifying and with certain themes. But I guess it can be done: a single frame bitmap that would only appear behind the currently selected icon?
But then, what type of bitmap/background? Or perhaps I could make it user selectable.
PostPosted: Sat Feb 13, 2016 7:17 pm
Well my idea is under the assumption you would not use magnification. So yes a single frame bitmap should work but draw it over the dock icon instead of behind. So that basically a user could make a simple Taskbar that looks like the default win10 one butbut with the added functionality of nexus. And yes user selectable would be cool!
Users browsing this forum: Amazon [Bot] and 266 guests
