 Post subject: New theme in the making!
PostPosted: Thu Mar 08, 2007 11:28 am
Quick preview of a new theme I'm making, heavilly based on the default Winstep Aero theme (maybe I'll call this one AeroSky :D ).
You can also see the new balloon tooltip under Wanda. EDIT: you can now see the new balloon tooltip AND the new weather forecast under the weather module. :D
Anyway, still a long way from being finished, but what do you think?
PostPosted: Thu Mar 08, 2007 1:22 pm
Yes! Looks great. I'm ready whenever you are.
PostPosted: Thu Mar 08, 2007 3:27 pm
Looks good Jorge. Keep up the great work.
Winstep just works so smooth with Windowblinds.
PostPosted: Fri Mar 09, 2007 5:14 am
very nice!!!!!
cef100
PostPosted: Fri Mar 09, 2007 11:10 am
Looks great. May I ask why you'd use the 'flag' in the start button? I've been curious about this in 'many a theme' to be honest :)
http://www.scarebear.org/
PostPosted: Fri Mar 09, 2007 11:55 am
Because the real Windows Start button has a flag..? That one, for instance, colors up on mouse over.
PostPosted: Fri Mar 09, 2007 12:01 pm
Fair enough :) I got into skinning because I like to change away from the Microsoft look and feel. The flag thing always makes me wonder :) I'm weird that way ;)
I thought you should use the WinStep 'W' logo instead :D
Get your own brand out there...
PostPosted: Sat Mar 10, 2007 9:49 am
Hehe. The problem is that the Winstep logo doesn't scale down well... :D
Anyway, this thing with me making themes - I'm not a skinner, remember - is actually turning out to be a good thing: I've run into limitations and obscure bugs that I would otherwise not be aware of. The difference is that I can fix them. :D
For instance, the desktop clock now supports bitmapped clock hands, and I'm about to add 'gauges' to the CPU, RAM and Net Meter desktop modules as well, so you can optionally display information in an analog gauge format.
PostPosted: Sat Mar 10, 2007 10:04 am
I'll have to give a theme a go with a 'W' in the start section. Or better yet, An 'X'! I think the Windows flag promotes Windows (duh!) when you ? with Xtreme ? are creating something that makes the operating system so much more.
I've been working in a marketing department for too long ;)
Clock hands. Let me just say "Awesome!" :D
PostPosted: Sat Mar 10, 2007 1:12 pm
Which reminds me: do you still have those little Winstep Xtreme buttons you made? :D
PostPosted: Sat Mar 10, 2007 1:28 pm
You have mail :)
PostPosted: Sat Mar 10, 2007 2:47 pm
Thank you, kind sir! :D
PostPosted: Sun Mar 11, 2007 8:51 am
Ok, I've updated the screenshot - all the modules are done. The clock is using the new bitmapped clock hands feature, and the CPU, ram and net meter modules are using the new gauge + gauge shadow (used for the needles) and module overlay features (used for the central dot and the glare effect on the small blue displays).
I based the cpu, ram and net meters on Tiggz's excellent KTEK skin for Sysmetrix - still have to ask him for permission, though. :oops:
Now I guess it's a question of taking care of the loose ends and a few details (I think I'll change the menu selection bar to blue, to match the task mouse over button, which unfortunately is not visible on this screenshot).
I won't be able to release the theme without first releasing another Winstep Xtreme version though, since this theme is so dependent on the new features.
PostPosted: Sun Mar 11, 2007 11:53 am
That looks great. I look forward to the next version of Xtreme and this skin. I love the new meters and clock hands. The clock hands look like they have shadow. Will the shadow always be on the correct side of the clock hand?
PostPosted: Sun Mar 11, 2007 6:39 pm
Yes!
The shadow is an optional second bitmap, which is shifted right and down from the clock center by 1 pixel before being rotated.
Users browsing this forum: Amazon [Bot] and 227 guests
